Interior Staircase Handrail Replacement
http://cdn.brownstoner.com/4e565e4c89266-.jpg
I am trying to replace a missing segment of a wooden handrail from an interior staircase. I would like to match the profile of the existing rail (pictured). I have seen this rail profile in other brownstones, but I can’t find it online. To complicate matters, the piece that I need curves up to connect the handrail to the newell post at the top of the staircase. I think it is called a neck or a gooseneck. Does anyone have any experience matching a handrail like this? I have tried a few salvage yards with no luck. Has anyone had something like this made? Any help would be appreciated. Thanks.
longhaul
in Architectural Salvage 13 years and 2 months ago
bricklayer | 12 years and 9 months ago
string(1) "1" object(WP_User)#5020 (8) { ["data"]=> object(stdClass)#5019 (12) { ["ID"]=> string(6) "179288" ["user_login"]=> string(10) "bricklayer" ["user_pass"]=> string(34) "$P$Bxw4v80QdM08S40Lkdo1nFp.utChdJ." ["user_nicename"]=> string(10) "bricklayer" ["user_email"]=> string(20) "sean@seanandlily.com" ["user_url"]=> string(25) "/forums/users/bricklayer/" ["user_registered"]=> string(19) "2017-08-10 14:40:10" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(10) "bricklayer" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(179288) ["caps"]=> array(2) { ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(2) { [0]=> string(10) "subscriber" [1]=> string(15) "bbp_participant" } ["allcaps"]=> array(4) { ["read"]=> bool(true) ["level_0"]=> bool(true) ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
Hi there longhaul, We have the exact handrail as you and are also looking for a way to fill in a missing segment. I’d appreciate in any direction / advice you have in finding a matching handrail. Thank you!
rh | 13 years and 2 months ago
string(1) "1" object(WP_User)#5018 (8) { ["data"]=> object(stdClass)#5049 (12) { ["ID"]=> string(4) "3878" ["user_login"]=> string(2) "rh" ["user_pass"]=> string(34) "$P$BL48JCuNvr9CIMtn9XLzqcR6qYGkGS1" ["user_nicename"]=> string(2) "rh" ["user_email"]=> string(22) "info@reclaimedhome.com" ["user_url"]=> string(27) "https:www.reclaimedhome.com" ["user_registered"]=> string(19) "2017-08-10 14:12:47" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(2) "rh" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(3878) ["caps"]=> array(2) { ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(2) { [0]=> string(10) "subscriber" [1]=> string(15) "bbp_participant" } ["allcaps"]=> array(4) { ["read"]=> bool(true) ["level_0"]=> bool(true) ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
If you can’t locate salvage, try Bill at Circular Stairs on Broadway. You’ll find his contact info in the archives. He can make one up to match.
