Deck Questions
Hello! Two questions about a potential back deck:
1. If backyard does not go back a full 30 feet can we still have a deck that is 8 ft deep? If no, can you point me to exactly why? Our house is a single family house in case it matters.
2. If the deck is made of steel, can decking that does not come within 3 ft of the property line include wood or must the whole thing be noncombustible if one side of the deck is at the line (the other is 3 ft away).
Thanks in advance for your help!
windyt
in General Discussion 2 months ago
michaelhanson | 2 months ago
object(WP_User)#5027 (8) {
  object(stdClass)#4798 (12) {
    string(6) "195380"
    string(13) "michaelhanson"
    string(34) "$P$BGvF7RaucQRwJnR7OCbehHIVgtaEXd1"
    string(23) "michael@hanson-arch.com"
    string(19) "2023-12-05 17:49:29"
    string(45) "1714766744:$P$BUU.OndFRkRLc9CmVmVZf.X7StOaek1"
    string(14) "Michael Hanson"
  int(195380)
Hi, Windyt – – a few thoughts on your questions:
1 – if your yard is 30′ deep, then you will be able to build a deck a maximum of 8′ off the rea wall of your building. But if it’s LESS than 30′ (sounds like the case), then it’s les likely – less than 30′ is an “existing noncompliance”, and the deck would be making that worse. Not necessarily impossible, but unlikely
2 – combustible materials need to be 3′ away from all property lines – both sides
Hope this helps!
