Electric Panel Upgrade
I currently have two 100 Amp panels one for the rental and another for my home. I was told that my panel is overloaded though I don’t trip breakers and there are no problems.
Nonetheless I want to purchase other appliances and add lights so I’m thinking of going to 200 Amp panel.
Can someone please confirm that this will need a permit?
Who would you recommend? My electrician is retired and I had an experience with another electrician who purposely disconnected lights to ramp up the scope of a small electric job. I discovered this quickly (architect here and electrician didn’t know this) and fired him. I’m a little gun shy of letting anyone just come in and do this job.
lourdesbernard
in General Discussion 1 month ago
kiltsjeremy | 0 months ago
object(WP_User)#5017 (8) {
  object(stdClass)#4786 (12) {
    string(6) "195355"
    string(11) "kiltsjeremy"
    string(34) "$P$BZn83QmyglWL96OOyF.sCwjlTWcQY.."
    string(18) "jeremykiltspropmgr"
    string(19) "airgraham@gmail.com"
    string(19) "2020-05-09 14:08:01"
  int(195355)
OMD Electrical Corp
(929) 231-2198
Jesse is a thoughtful load calculating electrician
cate | 1 month ago
object(WP_User)#5016 (8) {
  object(stdClass)#5015 (12) {
    string(34) "$P$BYXufkZr5bM3wNAI90wK6BdnwR5XTY."
The permit referred to below is not one the homeowner needs to file, the licensed electrician will handle, and it will not make your taxes increase.
Brownstone Home Inspection | 1 month ago
object(WP_User)#5018 (8) {
  object(stdClass)#5019 (12) {
    string(6) "191038"
    string(34) "$P$BJ3VGOQehURWl5p/rAASFRl7Lr.R4X/"
  int(191038)
It will require a permit. I am in the same situation you are in and can tell you this: have an electrician analyze your current usage and needs. They use calculations and perhaps tell you you do not need a new panel but can put a sub in.
Ceriello electric in brooklyn and midway in yonkers are two i recommend. I used to recommend munetz and my customers really liked him but he is doing more work on LI and less in here.
