Cypress Hills
Hi everyone.
As my handle suggests, we are former Bed Stuy residents and just bought in Cypress Hills.
If you are looking to buy and have a budget of under $1M this is a great place to look but a few suggestions.
20 minutes away from the new 170,000sf Netflix facility in Bushwick so this place will blow up as a result of the adjacency.
We bought between Fulton and Jamaica so we are walking distance to the park which has tennis, walking trails and baseball fields. It is very family and dog friendly.
There are plenty of places with garages if you look hard enough and time is limited to find something like this for under $1M. Street parking can be challenging if you come home late…not gonna lie.
If you travel a lot for work, the neighborhood is centrally located to LGA and JFK with both being about 15 minutes away.
The produce around here is amazing and you can get fresh coconut water right from the fruit for next to nothing.
You’ll definitely brush up on your Spanish.
That’s all.
peryoung
in Home Buying 2 years and 1 month ago
57
15595
cate | 2 years ago
string(1) "1" object(WP_User)#5076 (8) { ["data"]=> object(stdClass)#5064 (12) { ["ID"]=> string(6) "176696" ["user_login"]=> string(4) "cate" ["user_pass"]=> string(34) "$P$BYXufkZr5bM3wNAI90wK6BdnwR5XTY." ["user_nicename"]=> string(4) "cate" ["user_email"]=> string(20) "cate@brownstoner.com" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2017-08-10 14:24:59" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(13) "Cate Corcoran" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(176696) ["caps"]=> array(2) { ["administrator"]=> bool(true) ["editor"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(2) { [0]=> string(13) "administrator" [1]=> string(6) "editor" } ["allcaps"]=> array(191) { ["switch_themes"]=> bool(true) ["edit_themes"]=> bool(true) ["activate_plugins"]=> bool(true) ["edit_plugins"]=> bool(true) ["edit_users"]=> bool(true) ["edit_files"]=> bool(true) ["manage_options"]=> bool(true) ["moderate_comments"]=> bool(true) ["manage_categories"]=> bool(true) ["manage_links"]=> bool(true) ["upload_files"]=> bool(true) ["import"]=> bool(true) ["unfiltered_html"]=> bool(true) ["edit_posts"]=> bool(true) ["edit_others_posts"]=> bool(true) ["edit_published_posts"]=> bool(true) ["publish_posts"]=> bool(true) ["edit_pages"]=> bool(true) ["read"]=> bool(true) ["level_10"]=> bool(true) ["level_9"]=> bool(true) ["level_8"]=> bool(true) ["level_7"]=> bool(true) ["level_6"]=> bool(true) ["level_5"]=> bool(true) ["level_4"]=> bool(true) ["level_3"]=> bool(true) ["level_2"]=> bool(true) ["level_1"]=> bool(true) ["level_0"]=> bool(true) ["edit_others_pages"]=> bool(true) ["edit_published_pages"]=> bool(true) ["publish_pages"]=> bool(true) ["delete_pages"]=> bool(true) ["delete_others_pages"]=> bool(true) ["delete_published_pages"]=> bool(true) ["delete_posts"]=> bool(true) ["delete_others_posts"]=> bool(true) ["delete_published_posts"]=> bool(true) ["delete_private_posts"]=> bool(true) ["edit_private_posts"]=> bool(true) ["read_private_posts"]=> bool(true) ["delete_private_pages"]=> bool(true) ["edit_private_pages"]=> bool(true) ["read_private_pages"]=> bool(true) ["delete_users"]=> bool(true) ["create_users"]=> bool(true) ["unfiltered_upload"]=> bool(true) ["edit_dashboard"]=> bool(true) ["update_plugins"]=> bool(true) ["delete_plugins"]=> bool(true) ["install_plugins"]=> bool(true) ["update_themes"]=> bool(true) ["install_themes"]=> bool(true) ["update_core"]=> bool(true) ["list_users"]=> bool(true) ["remove_users"]=> bool(true) ["promote_users"]=> bool(true) ["edit_theme_options"]=> bool(true) ["delete_themes"]=> bool(true) ["export"]=> bool(true) ["NextGEN Gallery overview"]=> bool(true) ["NextGEN Use TinyMCE"]=> bool(true) ["NextGEN Upload images"]=> bool(true) ["NextGEN Manage gallery"]=> bool(true) ["NextGEN Manage tags"]=> bool(true) ["NextGEN Manage others gallery"]=> bool(true) ["NextGEN Edit album"]=> bool(true) ["NextGEN Change style"]=> bool(true) ["NextGEN Change options"]=> bool(true) ["email_users_notify"]=> bool(true) ["email_single_user"]=> bool(true) ["email_multiple_users"]=> bool(true) ["email_user_groups"]=> bool(true) ["NextGEN Attach Interface"]=> bool(true) ["copy_posts"]=> bool(true) ["ure_edit_roles"]=> bool(false) ["ure_create_roles"]=> bool(false) ["ure_delete_roles"]=> bool(false) ["ure_create_capabilities"]=> bool(false) ["ure_delete_capabilities"]=> bool(false) ["ure_manage_options"]=> bool(false) ["ure_reset_roles"]=> bool(false) ["edit_ads_txt"]=> bool(true) ["manage_feed_settings"]=> bool(true) ["edit_feed_source"]=> bool(true) ["read_feed_source"]=> bool(true) ["delete_feed_source"]=> bool(true) ["edit_feed_sources"]=> bool(true) ["edit_others_feed_sources"]=> bool(true) ["publish_feed_sources"]=> bool(true) ["read_private_feed_sources"]=> bool(true) ["delete_feed_sources"]=> bool(true) ["delete_private_feed_sources"]=> bool(true) ["delete_published_feed_sources"]=> bool(true) ["delete_others_feed_sources"]=> bool(true) ["edit_private_feed_sources"]=> bool(true) ["edit_published_feed_sources"]=> bool(true) ["manage_feed_source_terms"]=> bool(true) ["edit_feed_source_terms"]=> bool(true) ["delete_feed_source_terms"]=> bool(true) ["assign_feed_source_terms"]=> bool(true) ["edit_feed_item"]=> bool(true) ["read_feed_item"]=> bool(true) ["delete_feed_item"]=> bool(true) ["edit_feed_items"]=> bool(true) ["edit_others_feed_items"]=> bool(true) ["publish_feed_items"]=> bool(true) ["read_private_feed_items"]=> bool(true) ["delete_feed_items"]=> bool(true) ["delete_private_feed_items"]=> bool(true) ["delete_published_feed_items"]=> bool(true) ["delete_others_feed_items"]=> bool(true) ["edit_private_feed_items"]=> bool(true) ["edit_published_feed_items"]=> bool(true) ["manage_feed_item_terms"]=> bool(true) ["edit_feed_item_terms"]=> bool(true) ["delete_feed_item_terms"]=> bool(true) ["assign_feed_item_terms"]=> bool(true) ["edit_feed_blacklist"]=> bool(true) ["read_feed_blacklist"]=> bool(true) ["delete_feed_blacklist"]=> bool(true) ["edit_feed_blacklists"]=> bool(true) ["edit_others_feed_blacklists"]=> bool(true) ["publish_feed_blacklists"]=> bool(true) ["read_private_feed_blacklists"]=> bool(true) ["delete_feed_blacklists"]=> bool(true) ["delete_private_feed_blacklists"]=> bool(true) ["delete_published_feed_blacklists"]=> bool(true) ["delete_others_feed_blacklists"]=> bool(true) ["edit_private_feed_blacklists"]=> bool(true) ["edit_published_feed_blacklists"]=> bool(true) ["manage_feed_blacklist_terms"]=> bool(true) ["edit_feed_blacklist_terms"]=> bool(true) ["delete_feed_blacklist_terms"]=> bool(true) ["assign_feed_blacklist_terms"]=> bool(true) ["edit_feed_template"]=> bool(true) ["read_feed_template"]=> bool(true) ["delete_feed_template"]=> bool(true) ["edit_feed_templates"]=> bool(true) ["edit_others_feed_templates"]=> bool(true) ["publish_feed_templates"]=> bool(true) ["read_private_feed_templates"]=> bool(true) ["delete_feed_templates"]=> bool(true) ["delete_private_feed_templates"]=> bool(true) ["delete_published_feed_templates"]=> bool(true) ["delete_others_feed_templates"]=> bool(true) ["edit_private_feed_templates"]=> bool(true) ["edit_published_feed_templates"]=> bool(true) ["manage_feed_template_terms"]=> bool(true) ["edit_feed_template_terms"]=> bool(true) ["delete_feed_template_terms"]=> bool(true) ["assign_feed_template_terms"]=> bool(true) ["edit_shortcoder"]=> bool(true) ["read_shortcoder"]=> bool(true) ["delete_shortcoder"]=> bool(true) ["edit_shortcoders"]=> bool(true) ["edit_others_shortcoders"]=> bool(true) ["publish_shortcoders"]=> bool(true) ["delete_shortcoders"]=> bool(true) ["delete_published_shortcoders"]=> bool(true) ["delete_others_shortcoders"]=> bool(true) ["edit_published_shortcoders"]=> bool(true) ["aioseo_manage_seo"]=> bool(true) ["aioseo_page_analysis"]=> bool(true) ["aioseo_page_general_settings"]=> bool(true) ["aioseo_page_advanced_settings"]=> bool(true) ["aioseo_page_schema_settings"]=> bool(true) ["aioseo_page_social_settings"]=> bool(true) ["rank_math_edit_htaccess"]=> bool(true) ["rank_math_titles"]=> bool(true) ["rank_math_general"]=> bool(true) ["rank_math_sitemap"]=> bool(true) ["rank_math_404_monitor"]=> bool(true) ["rank_math_link_builder"]=> bool(true) ["rank_math_redirections"]=> bool(true) ["rank_math_role_manager"]=> bool(true) ["rank_math_search_console"]=> bool(true) ["rank_math_site_analysis"]=> bool(true) ["rank_math_onpage_analysis"]=> bool(true) ["rank_math_onpage_general"]=> bool(true) ["rank_math_onpage_advanced"]=> bool(true) ["rank_math_onpage_snippet"]=> bool(true) ["rank_math_onpage_social"]=> bool(true) ["rank_math_admin_bar"]=> bool(true) ["rank_math_analytics"]=> bool(true) ["rank_math_content_ai"]=> bool(true) ["srm_manage_redirects"]=> bool(true) ["SPF Manage Analytics"]=> bool(false) ["administrator"]=> bool(true) ["editor"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
I would love to do it again in the spring! Would love to meet everyone. So sorry I couldn’t make it either.
ladybug | 2 years ago
string(1) "1" object(WP_User)#5074 (8) { ["data"]=> object(stdClass)#5077 (12) { ["ID"]=> string(5) "40510" ["user_login"]=> string(7) "ladybug" ["user_pass"]=> string(34) "$P$BIQ/A6Hvtg1tHdQHikcQLwTAHe8UwV/" ["user_nicename"]=> string(7) "ladybug" ["user_email"]=> string(23) "michelleerfer@yahoo.com" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2017-08-10 13:50:26" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(7) "ladybug" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(40510) ["caps"]=> array(1) { ["bbp_participant"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(1) { [0]=> string(15) "bbp_participant" } ["allcaps"]=> array(1) { ["bbp_participant"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
let’s do it again in the Spring and get more Cypress Hills people. Was bummed that I couldn’t make it.
greenworks | 2 years ago
string(1) "1" object(WP_User)#5075 (8) { ["data"]=> object(stdClass)#5078 (12) { ["ID"]=> string(6) "193898" ["user_login"]=> string(10) "greenworks" ["user_pass"]=> string(34) "$P$BvxiXeodyQysgcTYowSaAwPkHGvc1S0" ["user_nicename"]=> string(10) "greenworks" ["user_email"]=> string(38) "greenworksconstruction936962@gmail.com" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2024-02-23 12:31:20" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(61) "Your first name Your last name Your first name Your last name" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(193898) ["caps"]=> array(1) { ["subscriber"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(1) { [0]=> string(10) "subscriber" } ["allcaps"]=> array(3) { ["read"]=> bool(true) ["level_0"]=> bool(true) ["subscriber"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
It was so much fun! It was just me and my husband from Cypress Hills in the end – couldn’t convince the two forum lurkers I know to come!
justinromeu26 | 2 years ago
string(1) "1" object(WP_User)#5076 (8) { ["data"]=> object(stdClass)#5079 (12) { ["ID"]=> string(6) "189743" ["user_login"]=> string(13) "justinromeu26" ["user_pass"]=> string(34) "$P$BjSWB1c5WUJ0DBogl53oBDpnZifM8J." ["user_nicename"]=> string(13) "justinromeu26" ["user_email"]=> string(23) "justinromeu26@gmail.com" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2022-05-10 20:48:00" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(61) "Your First Name Your Last Name Your First Name Your Last Name" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(189743) ["caps"]=> array(1) { ["subscriber"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(1) { [0]=> string(10) "subscriber" } ["allcaps"]=> array(3) { ["read"]=> bool(true) ["level_0"]=> bool(true) ["subscriber"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
It was really nice.
cate | 2 years ago
string(1) "1" object(WP_User)#5074 (8) { ["data"]=> object(stdClass)#5080 (12) { ["ID"]=> string(6) "176696" ["user_login"]=> string(4) "cate" ["user_pass"]=> string(34) "$P$BYXufkZr5bM3wNAI90wK6BdnwR5XTY." ["user_nicename"]=> string(4) "cate" ["user_email"]=> string(20) "cate@brownstoner.com" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2017-08-10 14:24:59" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(13) "Cate Corcoran" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(176696) ["caps"]=> array(2) { ["administrator"]=> bool(true) ["editor"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(2) { [0]=> string(13) "administrator" [1]=> string(6) "editor" } ["allcaps"]=> array(191) { ["switch_themes"]=> bool(true) ["edit_themes"]=> bool(true) ["activate_plugins"]=> bool(true) ["edit_plugins"]=> bool(true) ["edit_users"]=> bool(true) ["edit_files"]=> bool(true) ["manage_options"]=> bool(true) ["moderate_comments"]=> bool(true) ["manage_categories"]=> bool(true) ["manage_links"]=> bool(true) ["upload_files"]=> bool(true) ["import"]=> bool(true) ["unfiltered_html"]=> bool(true) ["edit_posts"]=> bool(true) ["edit_others_posts"]=> bool(true) ["edit_published_posts"]=> bool(true) ["publish_posts"]=> bool(true) ["edit_pages"]=> bool(true) ["read"]=> bool(true) ["level_10"]=> bool(true) ["level_9"]=> bool(true) ["level_8"]=> bool(true) ["level_7"]=> bool(true) ["level_6"]=> bool(true) ["level_5"]=> bool(true) ["level_4"]=> bool(true) ["level_3"]=> bool(true) ["level_2"]=> bool(true) ["level_1"]=> bool(true) ["level_0"]=> bool(true) ["edit_others_pages"]=> bool(true) ["edit_published_pages"]=> bool(true) ["publish_pages"]=> bool(true) ["delete_pages"]=> bool(true) ["delete_others_pages"]=> bool(true) ["delete_published_pages"]=> bool(true) ["delete_posts"]=> bool(true) ["delete_others_posts"]=> bool(true) ["delete_published_posts"]=> bool(true) ["delete_private_posts"]=> bool(true) ["edit_private_posts"]=> bool(true) ["read_private_posts"]=> bool(true) ["delete_private_pages"]=> bool(true) ["edit_private_pages"]=> bool(true) ["read_private_pages"]=> bool(true) ["delete_users"]=> bool(true) ["create_users"]=> bool(true) ["unfiltered_upload"]=> bool(true) ["edit_dashboard"]=> bool(true) ["update_plugins"]=> bool(true) ["delete_plugins"]=> bool(true) ["install_plugins"]=> bool(true) ["update_themes"]=> bool(true) ["install_themes"]=> bool(true) ["update_core"]=> bool(true) ["list_users"]=> bool(true) ["remove_users"]=> bool(true) ["promote_users"]=> bool(true) ["edit_theme_options"]=> bool(true) ["delete_themes"]=> bool(true) ["export"]=> bool(true) ["NextGEN Gallery overview"]=> bool(true) ["NextGEN Use TinyMCE"]=> bool(true) ["NextGEN Upload images"]=> bool(true) ["NextGEN Manage gallery"]=> bool(true) ["NextGEN Manage tags"]=> bool(true) ["NextGEN Manage others gallery"]=> bool(true) ["NextGEN Edit album"]=> bool(true) ["NextGEN Change style"]=> bool(true) ["NextGEN Change options"]=> bool(true) ["email_users_notify"]=> bool(true) ["email_single_user"]=> bool(true) ["email_multiple_users"]=> bool(true) ["email_user_groups"]=> bool(true) ["NextGEN Attach Interface"]=> bool(true) ["copy_posts"]=> bool(true) ["ure_edit_roles"]=> bool(false) ["ure_create_roles"]=> bool(false) ["ure_delete_roles"]=> bool(false) ["ure_create_capabilities"]=> bool(false) ["ure_delete_capabilities"]=> bool(false) ["ure_manage_options"]=> bool(false) ["ure_reset_roles"]=> bool(false) ["edit_ads_txt"]=> bool(true) ["manage_feed_settings"]=> bool(true) ["edit_feed_source"]=> bool(true) ["read_feed_source"]=> bool(true) ["delete_feed_source"]=> bool(true) ["edit_feed_sources"]=> bool(true) ["edit_others_feed_sources"]=> bool(true) ["publish_feed_sources"]=> bool(true) ["read_private_feed_sources"]=> bool(true) ["delete_feed_sources"]=> bool(true) ["delete_private_feed_sources"]=> bool(true) ["delete_published_feed_sources"]=> bool(true) ["delete_others_feed_sources"]=> bool(true) ["edit_private_feed_sources"]=> bool(true) ["edit_published_feed_sources"]=> bool(true) ["manage_feed_source_terms"]=> bool(true) ["edit_feed_source_terms"]=> bool(true) ["delete_feed_source_terms"]=> bool(true) ["assign_feed_source_terms"]=> bool(true) ["edit_feed_item"]=> bool(true) ["read_feed_item"]=> bool(true) ["delete_feed_item"]=> bool(true) ["edit_feed_items"]=> bool(true) ["edit_others_feed_items"]=> bool(true) ["publish_feed_items"]=> bool(true) ["read_private_feed_items"]=> bool(true) ["delete_feed_items"]=> bool(true) ["delete_private_feed_items"]=> bool(true) ["delete_published_feed_items"]=> bool(true) ["delete_others_feed_items"]=> bool(true) ["edit_private_feed_items"]=> bool(true) ["edit_published_feed_items"]=> bool(true) ["manage_feed_item_terms"]=> bool(true) ["edit_feed_item_terms"]=> bool(true) ["delete_feed_item_terms"]=> bool(true) ["assign_feed_item_terms"]=> bool(true) ["edit_feed_blacklist"]=> bool(true) ["read_feed_blacklist"]=> bool(true) ["delete_feed_blacklist"]=> bool(true) ["edit_feed_blacklists"]=> bool(true) ["edit_others_feed_blacklists"]=> bool(true) ["publish_feed_blacklists"]=> bool(true) ["read_private_feed_blacklists"]=> bool(true) ["delete_feed_blacklists"]=> bool(true) ["delete_private_feed_blacklists"]=> bool(true) ["delete_published_feed_blacklists"]=> bool(true) ["delete_others_feed_blacklists"]=> bool(true) ["edit_private_feed_blacklists"]=> bool(true) ["edit_published_feed_blacklists"]=> bool(true) ["manage_feed_blacklist_terms"]=> bool(true) ["edit_feed_blacklist_terms"]=> bool(true) ["delete_feed_blacklist_terms"]=> bool(true) ["assign_feed_blacklist_terms"]=> bool(true) ["edit_feed_template"]=> bool(true) ["read_feed_template"]=> bool(true) ["delete_feed_template"]=> bool(true) ["edit_feed_templates"]=> bool(true) ["edit_others_feed_templates"]=> bool(true) ["publish_feed_templates"]=> bool(true) ["read_private_feed_templates"]=> bool(true) ["delete_feed_templates"]=> bool(true) ["delete_private_feed_templates"]=> bool(true) ["delete_published_feed_templates"]=> bool(true) ["delete_others_feed_templates"]=> bool(true) ["edit_private_feed_templates"]=> bool(true) ["edit_published_feed_templates"]=> bool(true) ["manage_feed_template_terms"]=> bool(true) ["edit_feed_template_terms"]=> bool(true) ["delete_feed_template_terms"]=> bool(true) ["assign_feed_template_terms"]=> bool(true) ["edit_shortcoder"]=> bool(true) ["read_shortcoder"]=> bool(true) ["delete_shortcoder"]=> bool(true) ["edit_shortcoders"]=> bool(true) ["edit_others_shortcoders"]=> bool(true) ["publish_shortcoders"]=> bool(true) ["delete_shortcoders"]=> bool(true) ["delete_published_shortcoders"]=> bool(true) ["delete_others_shortcoders"]=> bool(true) ["edit_published_shortcoders"]=> bool(true) ["aioseo_manage_seo"]=> bool(true) ["aioseo_page_analysis"]=> bool(true) ["aioseo_page_general_settings"]=> bool(true) ["aioseo_page_advanced_settings"]=> bool(true) ["aioseo_page_schema_settings"]=> bool(true) ["aioseo_page_social_settings"]=> bool(true) ["rank_math_edit_htaccess"]=> bool(true) ["rank_math_titles"]=> bool(true) ["rank_math_general"]=> bool(true) ["rank_math_sitemap"]=> bool(true) ["rank_math_404_monitor"]=> bool(true) ["rank_math_link_builder"]=> bool(true) ["rank_math_redirections"]=> bool(true) ["rank_math_role_manager"]=> bool(true) ["rank_math_search_console"]=> bool(true) ["rank_math_site_analysis"]=> bool(true) ["rank_math_onpage_analysis"]=> bool(true) ["rank_math_onpage_general"]=> bool(true) ["rank_math_onpage_advanced"]=> bool(true) ["rank_math_onpage_snippet"]=> bool(true) ["rank_math_onpage_social"]=> bool(true) ["rank_math_admin_bar"]=> bool(true) ["rank_math_analytics"]=> bool(true) ["rank_math_content_ai"]=> bool(true) ["srm_manage_redirects"]=> bool(true) ["SPF Manage Analytics"]=> bool(false) ["administrator"]=> bool(true) ["editor"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
That’s great! Were many people from Cypress Hills?
in Home Buying 2 years ago
string(1) "2" object(WP_User)#5074 (8) { ["data"]=> object(stdClass)#5089 (12) { ["ID"]=> string(3) "779" ["user_login"]=> string(13) "RobertGMarvin" ["user_pass"]=> string(0) "" ["user_nicename"]=> string(13) "RobertGMarvin" ["user_email"]=> string(40) "64df18426207ddf12f1789eba7eabd04a9c3f615" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2007-08-10 18:03:45" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(10) "Bob Marvin" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(779) ["caps"]=> array(0) { } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(0) { } ["allcaps"]=> array(0) { } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
There were something like eight people—not a bad turnout
string(1) "1" object(WP_User)#5051 (8) { ["data"]=> object(stdClass)#5054 (12) { ["ID"]=> string(6) "193898" ["user_login"]=> string(10) "greenworks" ["user_pass"]=> string(34) "$P$BvxiXeodyQysgcTYowSaAwPkHGvc1S0" ["user_nicename"]=> string(10) "greenworks" ["user_email"]=> string(38) "greenworksconstruction936962@gmail.com" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2024-02-23 12:31:20" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(61) "Your first name Your last name Your first name Your last name" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(193898) ["caps"]=> array(1) { ["subscriber"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(1) { [0]=> string(10) "subscriber" } ["allcaps"]=> array(3) { ["read"]=> bool(true) ["level_0"]=> bool(true) ["subscriber"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
We’re here! Just said hi to Bob, wooo!
string(1) "1" object(WP_User)#5050 (8) { ["data"]=> object(stdClass)#5052 (12) { ["ID"]=> string(6) "189743" ["user_login"]=> string(13) "justinromeu26" ["user_pass"]=> string(34) "$P$BjSWB1c5WUJ0DBogl53oBDpnZifM8J." ["user_nicename"]=> string(13) "justinromeu26" ["user_email"]=> string(23) "justinromeu26@gmail.com" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2022-05-10 20:48:00" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(61) "Your First Name Your Last Name Your First Name Your Last Name" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(189743) ["caps"]=> array(1) { ["subscriber"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(1) { [0]=> string(10) "subscriber" } ["allcaps"]=> array(3) { ["read"]=> bool(true) ["level_0"]=> bool(true) ["subscriber"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
3-330 here as well
string(1) "2" object(WP_User)#5050 (8) { ["data"]=> object(stdClass)#5086 (12) { ["ID"]=> string(3) "779" ["user_login"]=> string(13) "RobertGMarvin" ["user_pass"]=> string(0) "" ["user_nicename"]=> string(13) "RobertGMarvin" ["user_email"]=> string(40) "64df18426207ddf12f1789eba7eabd04a9c3f615" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2007-08-10 18:03:45" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(10) "Bob Marvin" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(779) ["caps"]=> array(0) { } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(0) { } ["allcaps"]=> array(0) { } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
I’m here—no one else yet.
